Pipe Stress Due to Sustained Loads Formulae and Calculator
Pipe Stress Due to Sustained Loads Calculator and Equations per. ASME B31.3 - 2020
The equation for the stress due to sustained loads, such as pressure and weight, SL is given in Eq. 1. Equations for the stress due to sustained bending moments Sb, is given in Eq. 2.
Preview: Pipe Stress Due to Sustained Loads Calculator
SL = [ ( | Sa | + Sb )2 + ( 2 · St )2 ]0.5
Sb = [ ( Ii · Mi )2 + ( Io · Mo )2 ]0.5 / Z
Eq. 3
St = ( It · Mt ) / ( 2 · Z )
Eq. 4
Sa = ( Ia · Fa ) / Ap
SL = stress due to sustained loads
Sa =
axial stress range due to displacement strains
Sb
= bending stress range due to displacement strains
St = torsional stress-range due to displacement strains
Ii
= sustained in-plane moment index. In the absence of more-applicable data, Ii is taken as the greater of 0.75Ii or 1.00.
Io = sustained out-plane moment index.In the absence of more-applicable data, Io mistaken as the greater of 0.75Io or 1.00.
It = sustained torsional moment index. In the absence of more applicable data, It is taken as 1.00.
Ia = sustained longitudinal force index. in the adsence of more applicable data, Ia is taken as 1.00.
Mi = in-plane moment due to sustained loads,e.g., pressure and weight
Mo = out-plane moment due to sustained loads,e.g., pressure and weight
Mt = torsional moment due to sustained loads, e.g. pressure and weight
Z = sustained section modulus of pipe.
Ap = cross sectional area of the pipe, considering pipe dimensions less allowance
Fa = longitudinal force due to sustained loads, e.g. pressure and weight
ASME B31.1-2020, Paragraph 320.2
