I Beam Section Torque Deflection, Stress Equation and Calculator
Torque Applied Deformation and Stress of a I Beam Section Equations and Calculator
Torque Applied Deformation and Stress of a Trapezoid Calculator
Preview
Torque Applied Deformation and Stress of a I Beam Section Calculator
K = 2K1 + K2 + 2αD4
t = b if b < d,
t = d if d < b,
t1 = b if b > d,
t1 = d if d > b
θ = ( T L ) / ( K G )
Shear Stress Maximum
A = 2 a b + d c + 4 (πr2/4)
θ = angle of twist (radians),
α = degrees,
a, b, c, d = Length as Indicated (in, mm),
D = Diameter (in, mm),
r = radius (in, mm),
