Frame Deflections Concentrated Moment on Horizontal Member Equations and Calculator
Frame Deflections with Concentrated Moment Applied on Horizontal Member Equations and Calculator.
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Moment Applied on Horizontal Member Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Loading Terms LPH
Loading Terms LPM
W = Load or Force (lbsf, N),
