Estimating UAV Drone Propeller Thrust Equations and Calculator
Applications & Design
The following equations were derived from internet sources and experience. The defaults used within the calculator calculates results that are similar to the actual performance of the quad copter considered therefore use with the understanding that results are estimates.
Actual motor and propeller thurst and performance data is best obtained with fucntional testing methods.
Kv Rating on Brushless Motors, Kv is the Constant voltage rating of the Brushless Motor.
Theoretical Kv to rpm equation
rpm = Kv · V
where:
Kv = rating of motor
V = volts applied
Power produced by motor
P = k · Rp3 · D4 · Pt
Where
k = Average propeller ( 5.3 · 10-15 )
Rp = revolution per minute
D = propeller diameter
Pt = Propeller pitch
Ampere rating of battery
Amp rating = Amp hours· Discharge rate
Maximum Motor Wattage
Max Wattage = Volts · Amp Hours
Motor propeller combination Lift force (thrust)
T = [ π / 2 · D2 · ρ · P2 ]0.5
Where
ρ = air density (1.18 kg/m3 at ~ 25° C),
P = power
Misc. internet sources and experience
DeltaLima Poster on Stackexchange
