Elongated Section Torque Applied Equation and Calculator
Torsion Applied Deformation and Stress of any elongated section with axis of symmetry OX; Equations and Calculator
Preview
Torsion Applied Deformation and Stress of any elongated section with axis of symmetry Calculator
Shear Stress Maximum
θ = ( T L ) / ( K G )
For all solid sections of irregular form the maximum shear stress occurs at or very near one of the points where the largest inscribed circle touches the boundary,* and of these, at the one where the curvature of the boundary is algebraically least. (Convexity represents positive and concavity negative curvature of the boundary.) At a point where the curvature is positive (boundary of section straight or convex) this maximum stress is given approximately by:
* Unless at some point on the boundary there is a sharp reentant angle, causing high local stress.
θ = angle of twist (radians),
α = degrees,
L = Length (in, mm),
D = Diameter of largest inscribed circle (in, mm),
Ix = moment of inertia about axis of symmetry (in4, mm4),
U = Center Line Length (in, mm),
