Elastic Frame Concentrated Load Reaction and Deflection Equations and Calculator
Concentrated Load on the Horizontal Member Elastic Frame Equations and Calculator
Loading Configuration
General Designations
Preview
Concentrated load on the Horizontal member elastic frames calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Va = W (l3 - a)/ l3
Vb = W a / l3
W = Load or Force (lbsf, N),
