Distributed Load Elastic Frame Deflection Equation and Calculator
Distributed Load on the Horizontal Member Elastic Frame Deflections Equations and Calculator
Distributed Load on the Horizontal Member Elastic Frame Equations and Calculator
Loading Configuration
General Designations
Preview
Distributed Load on the Horizontal Member Elastic Frame Deflections Calculator:
General reaction and deformation expressions with right and left ends pinned
Horizontal Deflection at A:
Angular Rotation at A:
Lph
Lpm
W = Load or Force (lbsf, N),
