Diameter Change Press and Shrink Fit Formulae and Calculator
Strength and Mechanics of Materials Menu
Diameter Change for Cylinder Press and Shrink Fits Analysis Equations and Calculator
Premium membership required for access to calculator
Preview Diameter Change for Cylinder Press and Shrink Fits Analysis Calculator
Press Fit Cylinders Contact and Interference
Figure 1 Press Fit Cylinders Contact and Interference
Change in Diameter
Δd = d εθ
The change in diameter of the inner member when subjected to contact pressure pc
Δdi = - ( pc dc ) / E [ ( dc2 + di2 ) / ( dc2 - di2 ) -v ]
The change in diameter of the outer member when subjected to contact pressure pc
Eq. 3
Δdo = ( pc dc ) / E [ ( do2 + dc2 ) / ( do2 - dc2 ) +v ]
The original difference in diameters of the two cylinders when the material of the members is the same
Eq. 4
δ = Δdo + Δdi
Eq. 4a
Δdo = pc dc / E [ ( do2 + dc2 ) / ( do2 - dc2 ) +v ]
Eq. 4b
Δdi
= pc dc / E [ ( dc2 + di2 ) / ( dc2 - di2 ) -v ]
The total change in the diameters of hub and hollow shaft due to contact pressure at their contact surface when the material of the members is the same
Eq. 5
δ = Δds + Δdh = ds - dh
Eq. 5a
Δds = pc ds / Es [ ( ds2 + di2 ) / ( ds2 - di2 ) - vs ]
Eq. 5b
Δdh = pc dh / Eh [ ( do2 + dh2 ) / ( do2 - ds2 ) - vh ] exactly
Eq. 5c
δ = pc dc / [ ( dc2 + di2 ) / ( Es ( dc2 - di2 ) ) -v ] + pc2 dc / Eh [ ( do2 + dh2 ) / ( do2 - ds2 ) - v ]
Eq. 5d - (approx.)
pc dc = [ ( dc2 + di2 ) / ( Es ( dc2 - di2 ) ) + ( do2 + dc2 ) / ( Eh ( do2 - dc2 ) ) - vs / Es + vh / Eh )
Tangential stress
Figure 2 Tangential stress, σθ
radial stress
Figure 3, radial stress σr
The shrinkage stress in the band (Fig. 2 & 3)
Eq. 6
σθ = E δ / dc
The contact pressure between cylinders at the surface of contact when the material of both the cylinders is same (Fig. 2)
Eq. 7
pc = ( E δ ( dc2 - di2 ) ( do2 - dc2 ) ) / ( 2 dc3 ( do2 - di2 ) )
The tangential stress at any radius r of outer cylinder (Fig. 2)
Eq. 8
σθ-o = pc dc2 / ( do2 - dc2 ) [ 1 + do2 / ( 4 ro2 ) ]
The tangential stress at any radius r of inner cylinder (Fig. 2)
Eq. 9
σθ-i = - pc dc2 / ( do2 - dc2 ) [ 1 + di2 / ( 4 ri2 ) ]
The radial stress at any radius r of outer cylinder (Fig. 2)
Eq. 10
σθ-o = - pc dc2 / ( do2 - dc2 ) [ do2 / ( 4 ro2 ) -1 ]
The radial stress at any radius r of inner cylinder (Fig. 2)
Eq. 11
σθ-i = pc dc2 / ( dc2 - di2 ) / 1 - di2 / ( 4 ri2 ) ]
The tangential stress at outside diameter of outer cylinder (Fig. 2 & 3)
Eq. 12
σθ-oo = 2 pc dc2 / ( do2 - dc2 )
The tangential stress at inside diameter of outer cylinder (Fig. 2 & 3)
Eq. 13
σθ-oi = pc [ ( do2 + dc2 ) / ( do2 - dc2 ) ]
The tangential stress at outside diameter of inner cylinder (Fig. 2 & 3)
Eq. 14
σθ-io = - pc [ ( dc2 + di2 ) / ( dc2 - di2 ) ]
The tangential stress at inside diameter of inner cylinder (Fig. 2 & 3)
Eq. 15
σθ-ii = - 2 pc dc2 / ( dc2 - di2 )
The radial stress at outside diameter of outer cylinder (Fig. 2 & 3)
Eq. 16
σr-oo = 0
The radial stress at inside diameter of outer cylinder (Fig. 2 & 3)
Eq. 17
σr-oi = - pc
The radial stress at outside diameter of inner cylinder (Fig. 2 & 3)
Eq. 18
σr-io = - pc
The radial stress at inside diameter of inner cylinder (Fig. 2 & 3)
Eq. 19
σr-ii = 0
The semiempirical formula for tangential stress for cast-iron hub on steel shaft
Eq. 20
σθ = Eo δ / ( dc + 0.14 do )
Timoshenko equation for contact pressure in case of steel shaft on cast-iron hub
Eq. 21
pc = Eo δ / dc [ ( 1 - ( dc / do )2 ) / ( 1.53 + 0.47 ( dc / do )2 ) ]
for Es / Ec = 3
The allowable stress for brittle materials
Eq. 22
σall = σsu / n = [ ( Ec δ ( 1 + ( dc / do )2 ] / ( dc [ 1.53 + 0.47 ( dc / do )2 ]
where
ds = shaft outer diameter, m (in)
di = shaft inner diameter, m (in)
do = Outer hub diameter, m (in)
dh = Outer hub inner diameter, m (in)
ro = radius within outer cylinder material, m (in)
ri = radius within inner cylinder material, m (in)
dc = contact surface diameter, compressive, m (in)
pc = contact pressure MPa (psi)
σ = stress, MPa (psi)
δ = total change in diameter (interference), m (in)
E = modulus of elasticity, GPa (Mpsi)
Eh = modulus of elasticity of cast iron, GPa (Mpsi)
Es = modulus of elasticity of steel, GPa (Mpsi)
v = Poisson’s ratio
n = factor of safety
Machine Design Handbook 2nd Edition, 2001
Prof. Dr. K. Lingaiah
Former Principal, Professor and Head, Department of Mechanical Engineering
University Visvesvaraya College of Engineering, Bangalore University, Bangalore
