Cross Shaft Torsional Deflection, Stress Equation and Calculator
Torsional Deformation and Stress of a Cross Shaft Equations and Calculator
Torque Applied Deformation and Stress of a Four Grooved Pinned Shaft Equations and Calculator
Preview
Torque Applied Deformation and Stress of a Cross Shaft Section Calculator
K = 2Cs4
Varies with s / r as follows
For:
0   ≤   r / s ≤   0.9
θ = ( T L ) / ( K G )
Shear Stress Maximum
At M Location:
Where BM varies with r / s as follows:
for 0.1 ≤ r / s ≤ 0.5
At N Location:
Where BN varies with r / s as follows:
for 0.3≤ r / s ≤ 0.9
Note: BN > BM for r / s > 0.32
θ = angle of twist (radians),
r, s = Dimension as Indicated (in, mm),
