Concentrated Moment on the Horizontal Member 3 Frame Deflections Equations and Calculator
Concentrated Moment on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Concentrated moment on the horizontal member Elastic Frame Deflection
Loading Configuration
/General Elastic Frame Designations
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
General reaction and deformation expressions with right end pinned
LPh
LPM
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
