Concentrated Lateral Displacement 5 on the Horizontal Deflection Equation and Calculator
Concentrated Lateral Displacement on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
/General Elastic Frame Designations
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
Note: Δo could also be an increase in the length l1 or a decrease in the length l2.
LPH
LPM
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
