Concentrated Angular Displacement Left Vertical Member 9 Deflections Equation and Calculator
Concentrated Angular Displacement on Left Vertical Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Concentrated angular
Loading Configuration
General Designations
Preview
Frame Deflections with Concentrated Angular Displacement Calculator:
Since ψA = 0 and HA = 0
Note: Δo could also be an increase in the length l1 or a decrease in the length l2.
LPH = θo (a)
LPM = 0
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
