Concentrated Angular Displacement 4 Deflection Equation and Calculator
Concentrated Angular Displacement on the Horizontal Member Elastic Frame Deflection Left Vertical Member Guided Horizontally, Right End Pinned Equation and Calculator.
Loading Configuration
/General Elastic Frame Designations
General Designations
Preview
Frame Deflections with Concentrated Moment Calculator:
Since ψA = 0 and HA = 0
LPH
Δo = Displacement (in, mm),
W = Load or Force (lbsf, N),
