Circular Section Deformation and Stress Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Circular Section Equations and Calculator.
Preview
Torsional Deformation and Stress Solid Circular Sector Calculator
K = Cr4 where C varies with α / π as follows:
For 0 ≤ α / π ≤ 2.0
C = 0.0034 - 0.0697 (α / π) + 0.5825 (α / π)2 - 0.2950 (α / π)3 + 0.0874 (α / π)4 - 0.0111 (α / π)5
θ = ( T L ) / ( K G )
Shear Stress
For 0 ≤ α / π ≤ 1.0
B = 0.0117 - 0.2137 (α / π) + 2.2475 (α / π)2 - 4.6709 (α / π)3 + 5.1764 (α / π)4 - 2.2000 (α / π)5
τmax = T / B r3 on a radial boundary
θ = angle of twist (radians)
α = degrees
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
r = Radius (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
