Solder Joint - Tube Joint Calculation / Formula - Torque
Solder tube in tube (pipe in pipe) joint torque equations for stress intension, stress in shear, tensile stress in soldered joint.
Solder tube
Joint allowable stress in shear
Shear stress from force
Shear stress from moment
Resulting reduced stress
Strength check
tred tA
S Minimum Overlap Depth
Optimal Overlap Depth (L)
Lopt = max {Lmin, L1} [mm]
where:
SUS
joint strength in shear [MPa]
kS
shear safety coefficient
F
transferred force [N]
d
step diameter [mm]
L
step depth [mm]
Mk
torque [MPa]
SUb
tensile strength of basic material [MPa]
