Tangential Loading Only Spherical Cylinder Stress and Deflection Formulas and Calculator
Spherical Cylinder Stress and Deflection Tangential loading only; resultant load = P Equation and Calculator.
Preview: Spherical Cylinder Stress and Deflection Internal or External Pressure Calculator
Spherical Cylinder
resultant load = P
Deflection and Stress Own weight, δ force/unit volume; tangential top edge support.
For R2 / t > 10
Meridional Stress
Meridional Stress
Circumferential Hoop Stress
Change in height dimension y
Where used:
v = Poisson's ratio
P = Total force applied (lbs)
σ1,2 = Stress, (lbs/in2)
R2 = Radius (in)
R = Distance as indicated (in)
y = Depth as indicated (in), Must be equal too or less than d
t = Wall thickness (in)
θ = Angle (deg.)
θo = Angle (deg.)
(Note: θo is the angle to the lower edge and cannot go to zero without local bending occurring in the shell)
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
