Heats of Combustion
Power Transmission and Technology
Heats of Combustion for Common Compounds
Heats of Combustion is the amount of heat released per unit mass or unit volume of a substance when the substance is completely burned.
substance | molecular weight |
specific volume (ft3/lbm) |
heat of combustion |
Btu/ft3 |
Btu/lbm |
gross (high) |
net (low) |
gross (high) |
net (low) |
carbon | 12.01 |
- | 14,093 | 14,093 |
carbon dioxide | 44.01 | 8.548 |
carbon monoxide | 28.01 | 13.506 | 322 | 322 | 4347 | 4347 |
hydrogen | 2.016 | 187.723 | 325 | 275 | 60,958 | 51,623 |
nitrogen | 28.016 | 13.443 |
oxygen | 32.000 | 11.819 |
paraffin series (alkanes) | ||||||
methane | 16.041 | 23.565 | 1013 | 913 | 23,879 | 21,520 |
ethane | 30.067 | 12.455 | 1792 | 1641 | 22,320 | 20,432 |
propane | 44.092 | 8.365 | 2590 | 2385 | 21,661 | 19,944 |
n-butane | 58.118 | 6.321 | 3370 | 3113 | 21,308 | 19,680 |
isobutane | 58.118 | 6.321 | 3363 | 3105 | 21,257 | 19,629 |
n-pentane | 72.144 | 5.252 | 4016 | 3709 | 21,091 | 19,517 |
isopentane | 72.144 | 5.252 | 4008 | 3716 | 21,052 | 19,478 |
neopentane | 72.144 | 5.252 | 3993 | 3693 | 20,970 | 19,396 |
n-hexane | 86.169 | 4.398 | 4762 | 4412 | 20,940 | 19,403 |
olefin series (alkenes and alkynes) | ||||||
ethylene | 28.051 | 13.412 | 1614 | 1513 | 21,644 | 20,295 |
propylene | 42.077 | 9.007 | 2336 | 2186 | 21,041 | 19,691 |
n-butene | 56.102 | 6.756 | 3084 | 2885 | 20,840 | 19,496 |
isobutene | 56.102 | 6.756 | 3068 | 2869 | 20,730 | 19,382 |
n-pentene | 70.128 | 5.400 | 3836 | 3586 | 20,712 | 19,363 |
aromatic series | ||||||
benzene | 78.107 | 4.852 | 3751 | 3601 | 18,210 | 17,480 |
toluene | 92.132 | 4.113 | 4484 | 4284 | 18,440 | 17,620 |
xylene | 106.158 | 3.567 | 5230 | 4980 | 18,650 | 17,760 |
miscellaneous fuels | ||||||
acetylene | 26.036 | 14.344 | 1499 | 1448 | 21,500 | 20,776 |
air | 28.967 | 13.063 |
ammonia | 17.031 | 21.914 | 441 | 365 | 9668 | 8001 |
digester gasb | 25.8 | 18.3 | 658 | 593 | 15,521 | 13,988 |
ethyl alcohol | 46.067 | 8.221 | 1600 | 1451 | 13,161 | 11,929 |
hydrogen sulfide | 34.076 | 10.979 | 647 | 596 | 7100 | 6545 |
iso-octane | 114.2 | 0.0232c | 106 | 98.9 | 20,590 | 19,160 |
methyl alcohol | 32.041 | 11.820 | 868 | 768 | 10,259 | 9078 |
naphthalene | 128.162 | 2.955 | 5854 | 5654 | 17,298 | 16,708 |
sulfur | 32.06 |
- | 3983 | 3983 |
sulfur dioxide | 64.06 | 5.770 |
water vapor | 18.016 | 21.017 |
(Multiply Btu/lbm by 2.326 to obtain kJ/kg.)
(Multiply Btu/ft3 by 37.25 to obtain kJ/m3.)
aGas volumes listed are at 60°F (16°C) and 1 atm.
bDigester gas from wastewater treatment plants is approximately 65% methane and 35% carbon dioxide by volume. Use composite properties of these two gases.
cliquid form; stoichiometric mixture
- Saturated Liquids Thermal Properties
- Thermal Properties of Gases
- Boiling and freezing point properties of selected substances
- Benedict-Webb-Rubin PVT Formula and Calculator
- Specific Heat of Aqueous Solutions of Propylene Glycol
- Heat Transfer Coefficient for Condensation Formula and Calculator
- Heating Capacity of a Radiator Formula and Calculator
- API Gravity Gravity Equations and Calculator
- Petroleum Refining Volume 1
- Principles of Chemical Engineering Design
