Related Resources: fluid flow
Viscosity Grade Table ISO 3448
Civil Engineering Application & Design Resources
ISO 3448 Viscosity Grade Table
The ISO viscosity grade (VG) as specified in ISO 3448, is commonly used to classify oils. (See Table 1) Viscosity at 10°F (40°C), the approximate temperature of machinery, in centistokes (same as mm2/s), is used as the index. Each subsequent viscosity grade within the classification has approximately a 50% higher viscosity, whereas the minimum and maximum values of each grade range ±10% from the midpoint.
ISO 3448
viscosity grade
kinematic viscosity at 40°C (cSt)
Min.
Midpoint
Max
ISO VG 2
1.98
2.2
2.42
ISO VG 3
2.88
3.2
3.52
ISO VG 5
4.14
4.6
5.06
ISO VG 5
4.14
4.6
5.06
ISO VG 10
9.0
10
11.0
ISO VG 15
13.5
15
16.5
ISO VG 22
19.8
22
24.2
ISO VG 32
28.8
32
35.2
ISO VG 46
41.4
46
50.6
ISO VG 68
61.2
68
74.8
ISO VG 100
90
100
110
ISO VG 150
135
150
165
ISO VG 220
198
220
242
ISO VG 320
288
320
352
ISO VG 460
414
460
506
ISO VG 680
612
680
748
ISO VG 1000
900
1000
1100
ISO VG 1500
1350
1500
1650
Civil Engineering Reference Manual, Fourteenth Edition
Michael R. Lindeburg, PE
