Related Resources: fluid flow
Gas Compressibility Factor
Gas Compressibility Factor ( Gas Deviation Factor)
The gas compressibility factor or gas deviation factor is a measure of how close a real gas is to an ideal gas. The compressibility factor Z is a dimensionless number close to 1.00. It is independent of the quantity of gas. It depends on the gravity, temperature, and pressure of the gas.
For example, a sample of natural gas may have a Z value of 0.8595 at 1000 psia and 70°F. Charts are available that show the variation of Z with temperature and pressure
A related term called the supercompressibility factor Fpv is defined as follows:
Equation 1
Fpv = 1 / Z1/2
or
Equation 2
Z = 1 / Fpv2
Several methods are available to calculate the value of Z at a temperature T and pressure P. One approach requires knowledge of the critical temperature and pressure of the gas mixture. The reduced temperature and pressure are calculated from the critical temperatures and pressures as follows:
Equation 3
Reduced temperature = T / Tc
Equation 4
Reduced pressure = P / Pc
where temperatures and pressures are in absolute units.
The value of the compressibility factor Z is calculated using one of the following methods:
  • Standing and Katz method
  • Hall-Yarborough method
  • Dranchuk, Purvis, and Robinson method
  • AGA method
  • CNGA method
  • Piping Calculations Manual,
    E. Shashi Menon
    SYSTEK Technologies, Inc
