Soil Loading Under Pavement
Soil Loading Under Pavement, also called California Bearing Ratio.
The California bearing ratio (CBR) is often used as a measure of the quality of strength of a soil that underlies a pavement, for determining the thickness of the pavement, its base, and other layers. This penetration test was originally completed to evaluate of the mechanical strength of road subgrades and military base courses. It was developed by the California Department of Transportation before World War II.
The test is performed by measuring the pressure required to penetrate a soil sample with a plunger of standard area. The measured pressure is then divided by the pressure required to achieve an equal penetration on a standard crushed rock material. The CBR test is described in ASTM Standards D1883-05 (for laboratory-prepared samples) and D4429 (for soils in place in field), and AASHTO T193. The CBR test is fully described in BS 1377 : Soils for civil engineering purposes : Part 4, Compaction related tests.
where:
F force per unit area required to penetrate a soil mass with a 3-in2 (1935.6-mm2) circular piston (about 2 in (50.8 mm) in diameter) at the rate of 0.05 in/min (1.27 mm/min); and  F0 force per unit area required for corresponding penetration of a standard material.
Typically, the ratio is determined at 0.10-in (2.54-mm) penetration, although other penetrations sometimes are used. An excellent base course has a CBR of 100 percent. A compacted soil may have a CBR of 50 percent, whereas a weaker soil may have a CBR of 10.
