Vaporization Rate Equation and Calculator
Vaporization Rate (Qm, mass time) from a Liquid Surface Equation and Calculator
The rate of evaporation depends only on the surface area of the liquid and is essentially constant . The rate of condensation depends on the number of molecules in the vapor phase and increases steadily until it equals the rate of evaporation.
Qm = [ M · K · As · Psat ] / ( Rg · TL )
M = molecular weight of volatile substance
K = mass-transfer coefficient
As = area of liquid surface
Psat = saturation vapor pressure of the pure liquid at TL
Rg = ideal gas constant
TL = absolute temperature of the liquid
Reference
- The Fundamentals of Engineering (FE) Handbook, 2020
- Steady Flow Vapor Power Cycles Thermodynamics – Rankine Cycle - Class 12
- Water Vapor Permeability
- Water Vapor Saturation Pressure Formulae and Calculator
- Saturated and Superheated Vapors - Thermodynamics
- Water Vapor Released by Humans
- Quality Vapor and Mass Thermodynamics
- Flash Point Liquids, Gases, Vapors and Solvents
- Water Vapor Density
- Vapor Pressure of Ice Table
- Vapor Pressure Spreadsheet
- Vapor Saturation Pressure Over Ice Formulas and Calculator
