Uniform Force Over Entire Plate Beam Stress and Deflection Equations and Calculator
Flat Rectangular Uniform over entire plate plus uniform tension or compression P lb/linear in applied to short edges Stress and deflection Equation and Calculator.
Per. Roarks Formulas for Stress and Strain Formulas for flat plates with straight boundaries and constant thickness
Stress Maximum (Equations for σa and σb are stresses due to bending only;):
Stress Maximum Including Direct Stress and σa
+ P/t |
Where α βx and βy depend on ratios a / b and P / PE where:
Deflection:
Symbols used:
E = Modulus of Elasticity (N/m2, lbs/2)
q = Applied Load or Force to Flat Area of Plate (N/m2, lbs/2)
P = Tension or Compression to Short Edges (N/m, Lbs/in)
t = plate thickness, (m, in)
a = plate length, (m, in)
b = plate width, (m, in)
σ max = maximum stress, (N/m2, lbs/in2)
ymax = Maximum deflection (m, in)
α = From Table A
βx = From Table A
βy = From Table A
Table A (Click on Table to enlarge in Pop-up Window)
