Tire Traction Force Equation and Calculator
Engineering and Design Applications
Tire Traction Breakaway Equation and Calculator
Tire Traction Force, or tractive force, is the  force  used to generate  motion  between a car or truck and the road or tangential surface.
Tire Traction can also refer to the maximum tractive force between a body and a surface, as limited by available friction; when this is the case, traction is often expressed as the ratio of the maximum tractive force to the  normal force  and is termed the  coefficient of traction.
Tractive Force
Applied tractive force based on engine torque equation:
Fz = [ 2 · π · Mmot · η · iG · iv · iA ] / U
Where ,
Fz = Tractive force in N
Mmot = Engine torque in Nm
η = Overall efficiency of power train (see table below)
iG = Transmission ratio)
iv = Driving axle ratio
iA = Final drive atio of the driven axle(s)
U = Tire rolling Circumference = 2 · π · r in m
r = Tire radius in m
Overall Efficiency in the Drive Train
Number of Driven Axles η
One axle 0.95
Two Axles 0.90
Three axles 0.85
Four axles 0.80
Coefficient of traction : The  coefficient of traction  is defined as the usable force for traction divided by the weight on the running gear (wheels, tracks etc.).
usable traction = coefficient of traction x normal force
Factors affecting coefficient of traction
Tire traction between two surfaces depends on several factors:
  • Material composition of each surface.
  • Macroscopic and microscopic shape ( texture ;  macrotexture  and  microtexture )
  • Normal force  pressing contact surfaces together.
  • Contaminants at the material boundary including lubricants and adhesives.
  • Relative motion of tractive surfaces - a sliding object (one in kinetic friction) has less traction than a non-sliding object (one in static friction).
  • Direction of traction relative to some coordinate system - e.g., the available traction of a tire often differs between cornering, accelerating, and braking.
  • For low-friction surfaces, such as off-road or ice, traction can be increased by using traction devices that partially penetrate the surface; these devices use the shear strength of the underlying surface rather than relying solely on dry friction (e.g., aggressive off-road  tread  or  snow chains )....
The maximum permissible traction or force that can be applied to the wheels is governed by two things: the weight of the vehicle and the adhesion coefficient between the tire and the road surface.
More the weight and the adhesion coefficient, more amount of tractive force can be applied to the wheels without causing slips between the tires and road.
In the design of wheeled or tracked vehicles, high traction between wheel and ground is more desirable than low traction, as it allows for higher acceleration (including cornering and braking) without wheel slippage. One notable exception is in the motorsport technique of  drifting , in which rear-wheel traction is purposely lost during high speed cornering.
In some applications, there is a complicated set of trade-offs in choosing materials. For example, soft rubbers often provide better traction but also wear faster and have higher losses when flexed—thus reducing fuel and rolling efficiency.
The traction of trucks, agricultural tractors, wheeled military vehicles, etc. when driving on soft and/or slippery ground can be improved significantly by use of Tire Pressure Control Systems (TPCS). A TPCS makes it possible to reduce and later restore the tire pressure during continuous vehicle operation. Increasing traction by use of a TPCS also reduces tire wear and ride vibration.
References
Kelly Bramble, ASME-S-GDTP, A&P, Engineers Edge, LLC
Tushar Sirdeshmukh , B.Tech Mechanical Engineering, Visvesvaraya National Institute of Technology,Nagpur
