Tapered Flat spring cantilevered Design equations and calculator
Beam Stress Deflection Equations and Calculators
Spring Design Equations and Calculators
Flat spring design equations and calculator: The equations are based on standard beam formulas where the deflection is small.
Flat spring cantilevered design tapered geometry equations and calculator.
Deflection:
eq. 1Flat spring cantilevered design tapered geometry equations and calculator
F = 5.22 P L3 / E b t3
eq. 2
F = 0.87 Sb L2 / E t
Load:
eq. 3
P = Sb b t2 / 6 L
eq. 4
P = E b t3 F / ( 5.22 L3 )
Stress, Bending:
eq. 5
Sb = 6 P L / b t2
eq. 6
Sb = E t F / 0.87 L2
Thickness, Spring:
eq. 7
t = 0.87 Sb L2 / E F
eq.8
t = ( 5.22 P L3 / ( E b F ) )(1/3)
P = Load, (lbs),
L = Active length subject to deflection (inches),
b = Widest width of spring (in),
E = Modulus of Elasticity in Tension, (lbs/in2),
t = Thickness, (in),
Sb = Stress, bending (lbs/in2),
F - Deflection, for on active section (in)
Machinery Handbook, 27th edition
