Stress at Threaded Tube Connection Design Calculator
Threaded Connections Design and Calculations
Strength of Materials
Stress at Threaded Connections Between Two Tubes Design and Calculator
The following rules are stated for the case of threaded connections between two tube subjected to axial force, P. For the bolt-and-nut assembly, the same rules apply, by substituting Di = O.
Preview calculator: Design Stress at Threaded Connections Between Two Tubes Calculator
Eq. 1 Tensile stress in outer tube at root section of thread
f t = P Π 4 [ D o 2 ( D n + f ) 2 ]
Eq. 2 Tensile stress in outer tube at relief groove
f t = P Π 4 [ D o 2 D R o 2 ]
Eq. 3 Tensile stress in inner tube at root section of thread
f t = P Π 4 [ ( D N e ) 2 D 1 2 ]
Eq. 4 Tensile stress in inner tube at relief groove
f t = P Π 4 [ D R i 2 D i 2 ]
Eq. 5 Shear stress across threads, along a cylindrical surface having a diameter equal to the minimum pitch diameter.
f s = P F Π 2 ( D N c ) L
Eq. 5a
f s 4 P Π D L
Eq. 5b
f = U t o o t h L t o o t h
Eq. 5c Unloaded tooth
Utooth = Δo - ΔI
Tube to Tube threaded Connection
Figure 1 - Tube to Tube threaded Connection
Eq. 6 Bearing stress on the surface of contact between inner and outer threads.
f b r = P n L Π 4 [ ( D n a Δ I ) 2 ( D N b Δ O ) 2 ]
Eq. 7 Hoop compression stress in inner tube
f c = P 3 Π L ( D N c D I )
Eq. 7a The corresponding elastic decrease in diameter of the inner tube is
Δ I = f c E ( D N c )
Eq. 8 Hoop tension stress in outer tube
f t = P 3 Π L ( D o D N + d )
Eq. 8a
Δ o = f t E ( D N d )
Where
P =axial tensile force
DN = Nominal diameter
Do = Outer tube thread root diameter
Dro = Outer tube major diameter
Di = Inside tube inside diameter
Dri = Inside tube root diameter
L = Length of engagement
ΔI = elastic decrease in diameter of inner tube
ΔO = elastic increase in diameter of outer tube
a = Truncation of external thread root
b = Total single thread contact width
p = pitch
c = Difference between maximum major and pitch diameter of internal thread
d = Height if internal thread and depth of thread engagement
e = Double height of external thread
f = Addendum of external thread
ft = Tensile stress
Utooth = Unloaded tooth height
Ltooth = Loaded tooth height
L = Length of engaged thread
  • Bell Helicopter Structural Design Manual, 1977
Unloaded Tooth Height
