Straight Labyrinth Seal Flow Equation and Calculator
Straight Labyrinth Seal using Martin’s Equation and Calculator
Martin's equation is used for compressible flow with straight-through seals
Figure 1 Straight Labyrinth Seal
Preview Straight Labyrinth using Martin’s Equation Calculator
Martin’s equation for mass flow for straight labyrinth seals
m = A p t o 1 ( p n / p t 0 ) 2 R T t 0 [ n l n ( p n / p t 0 ) ]
where
m = mass flow rate (kg/s)
A = annular clearance area of the seal (m2)
pt0 = upstream total pressure (Pa)
pn = downstream static pressure (Pa)
R = characteristic gas constant (J / kg-K)
Tt0 = upstream total temperature (K)
n = number of labyrinth fins (-)
The mass flow function, Q, provides a convenient means for comparing the relative performance of different seals. This is defined by
Q = m T t 0 A p t 0
Substitution for the mass flow function Eq. 2 in Eq. 1 gives
Eq. 3
Q = 1 ( p n / p t 0 ) 2 R [ n l n ( p n / p t 0 ) ]
The flow characteristics for a straight labyrinth for compressible flow, using Eq 3 is illustrated in Figure 1.
Labyrinth mass flow function modeled
Figure 1 Labyrinth mass flow function modeled using Eq 3 (R = 287 J/Kg-K)
Peter R. N. Childs
2014
