Short Rectangular Membrane Stress and Deflection Calculator
Flat Plates Stress, Deflection Design Equations and Calculators
Short Rectangular Membrane Stress and Deflection Design Calculator and Equations
Figure 1 shows a short rectangular membrane (a / b < 5 ) clamped on four sides under a uniform pressure p.
Preview: Short Rectangular Membrane Stress and Deflection Design Calculator
The deflection at the center of this membrane given by
δ = n 1 a p a E t 3
where n1 is given in figure 1
The stress at various locations on short rectangular membranes are given by following equations for which the values of the coefficients n2 through n7 are given in figure 2.
Center of plate ( c = b / 2, y = a / 2 )
f x = n 2 p 2 E ( a t ) 2 3
Eq. 3
f y = n 3 p 2 E ( a t ) 2 3
Center of short side (x = b / 2, y = 0
Eq. 4
f x = n 4 p 2 E ( a t ) 2 3
Eq. 5
f y = n 5 p 2 E ( a t ) 2 3
Center of long side ( x = 0, y = a / 2 )
Eq. 6
f x = n 6 p 2 E ( a t ) 2 3
Eq. 7
f y = n 7 p 2 E ( a t ) 2 3
It should be noted that the maximum membrane stress at the center of the long side of the plate
Short Rectangular Membrane Clamped
Figure 1, Short Rectangular Membrane Clamped on Four Sides
Where
p = pressure
fmax = calculated stress
E = modulus of elasticity
a = length
b = width
t = thickness of membrane
δ = deflection
µ = poisson's ratio
Figure 2 Coefficients for Equations 1 - 7
(Premium membership require to view)
  • Bell Helicopter Structural Design Manual, 1977
