Engineers Edge
Thickness of Ellipsoidal Head Under Internal Pressure:
This calculator determines the thickness of a Ellipsoidal Head Under Internal Pressure with an internal pressure applied: Typical applications are propane tanks, compressed air storage tanks etc.
The "Joint Efficiency" reflects your confidence in the welded seam areas of the as-manufactured pressure vessel.
Note: When Thickness does not exceed one-half of the inside radius, or P does not exceed 1.25SE, use the following calculator.
Design Variables:
(P) = Design Pressure(internal) (psi) =
(D) = Inside Diameter of conical portion (in.) =
of a toriconical head at point of tangency
(S) = Max. Allowable Material Stress (psi) =
(E) Lowest Joint Efficiency (80% = .80) =
Results:
Minimum required wall thickness of shell (inches) =
© Copyright 2000 - 2020, by Engineers Edge, LLC www.engineersedge.com
Advertising | Contact | Privacy Policy
