Screw Threads Calculator for Internal Unified Inch Screw
ANSI Hardware Design Guide and Charts
Unified Inch Screw Threads Calculator for UN Threads
UN Internal Screw Threads Formulas and Calculator per. ASME B1.1
The formulas below are for inch screw threads are based on those listed in ASME B1.1, Unified Inch Screw Threads.
Basic Screw Thread Profile
Formulas Used:
Note that calculated values may be slightly different than table reference data due to math rounding differences.
Minimum internal minor diameter
D1min. = Dbsc - 2hn
2hn = 1.08253175P
where
Dbsc = Basic major diameter
2hn = double height of internal thread
P =  1/n
n = threads per inch
Eq. 3
D1max. = D1min. + TD1
Eq. 4
TD1 = 0.25P - 0.4P2
where
D1 max. = Maximum internal minor diameter
D1 min. = Minimum internal minor diameter
TD1 = internal minor diameter tolerance
Eq. 5
D2 min. = Dbsc − hb
Eq. 6
hb = 0.64951905P
where
D2min. = Minimum internal pitch diameter
D bsc = Basic major diameter
hb = twice the external thread addendum
Eq. 7
D2max. = D2 min. + TD2
Eq 8.
TD2 = 1 .300 Td2
Eq. 9
Td2 = 0.0015 (d bsc)1/3 + 0.0015 LE1/2 0.015 (P2)1/3
where
D2 max. = Maximum internal pitch diameter
D2 min. = Minimum internal pitch diameter
TD2 = internal pitch diameter tolerance
LE = length of engagement
P = thread pitch
Eq 10
D min. = D bsc
where
Dmin. = Minimum internal major diameter
Notes
(a) Maximum Major Diameter (Internal Threads ). In dimensioning internal threads, the maximum major diameter is not specified, being established by the crest of an unworn tool. In practice, the major diameter of an internal thread is satisfactory when accepted by a gage or gaging method that represents the maximum material condition of an external thread that has no allowance.
(b) Minimum Major Diameter (Internal Threads), Dbsc. For all classes, equals basic diameter Dbsc.
(c) Minimum Pitch Diameter. For all classes, D2bsc equals basic pitch diameter D2 minimum.
(d) Maximum Pitch Diameter (Internal Threads). For all classes, equals minimum pitch diameter D2bsc, plus pitch diameter tolerance for respective class of thread
(e) Minimum Minor Diameter (Internal Threads). For all classes, D1bsc equals minimum pitch diameter D2 minimum minus 0.43301122P, then rounded off to the nearest 0.001 in. for sizes 0.138 in. and larger. For Class 3B, a cipher is added to yield four decimal places.
(f) Maximum Minor Diameter (Internal Threads) . All classes are calculated before rounding, then rounded for Classes 1B and 2B to the nearest 0.001 in. for sizes 0.138 in. and larger. Class 3B values are rounded to four decimal places.
Plating considerations
Standard internal threads provide no allowance for coating thickness. To determine before coating gaging limits for a coated thread, increase
(a) the minimum pitch diameter by 4 times the maximum coating thickness, if specified, or by 6 times the minimum or nominal coating thickness, if not specified.
(b) the maximum pitch diameter by 4 times the minimum or nominal coating thickness.
(c) the minimum minor diameter by 2 times the maximum coating thickness, if specified, or by 3 times the minimum or nominal coating thickness, if not specified.
(d) the maximum minor diameter by 2 times the minimum or nominal coating thickness.
