Relative Humidity Calculator and Equation
Heat Transfer Engineering
Thermodynamics
Physics
Relative Humidity is by definition the percentage ratio of Vapor Pressure to Saturation Vapor Pressure and is a commonly used indicator of the amount of moisture in the air. Although there are instruments that can directly measure relative humidity, Wet Bulb Temperature is commonly measured to enable the calculation of Vapor pressure and thus relative humidity. Its measurement involves a mercury thermometer with the bulb covered by the end of a muslin wick and the other end of the wick immersed in water. Evaporation of water from the muslin cools the thermometer below the air temperature, or dry bulb temperature, to a temperature determined by the evaporation rate, which in turn is related to the moisture content of the air. Another common moisture parameter is Dew Point Temperature, which is calculated from wet and dry bulb temperature or from relative humidity and dry bulb temperature. The dew point temperature is a direct measure of the atmospheric moisture content and physically corresponds with the temperature to which the air must be reduced for moisture in the air to condense and thus form dew.
The equations below are applicable only when the air temperature is greater than or equal to 0.0 ºC. For temperatures below 0.0 ºC, the constants in the equations must be adjusted to reflect possible phase changes.
The following equations allow Relative Humidity to be calculated given the known parameters:
Wet Bulb Temperature, Dry Bulb Temperature, and Location Elevation Pressure
U = 100 [ exp[1.8096 +( ( 17.2694 Tw ) / ( 237.3 + Tw ) ) ] - 7.866x10-4 P ( T - Tw ) ( 1 + Tw/610 ) ]
/ exp [ 1.8096 + ( ( 17.2694 T ) / ( 237.3 + T ) )]
where
U = Relative Humidity (%),
T = Dry Bulb Temperature (°C),
Tw = Wet Bulb Temperature (°C),
P = Station Level Pressure (hPa)
Wet-bulb temperature Tw is the temperature at which water (liquid or solid), by evaporating into moist air at dry bulb temperature t and humidity ratio W, can bring air to saturation adiabatically at the same temperature Tw while total pressure p is constant.
If pressure is not known, the following table of standard pressures can be used as a first guess.
Standard Sea level 1013.25 hPa, or 1 atmosphere 9atm), or 29.92 inches of mercury
Station Altitude (m) | 0 - 250 |
251 - 500 |
501 - 750 |
1001 - 1250 |
1251 - 1500 |
Pressure (hPa) | 998.3 |
969.0 |
940.4 |
912.5 |
885.2 |
The calculated relative humidity given an accurately measured station level pressure is expected to vary by 2-3% from the value calculated using a pressure from the above table.
Dry Bulb Temperature and Dew Point Temperature
U = 100 [ exp[1.8096 +( ( 17.2694 Td ) / ( 237.3 + Td ) ) ] / exp [ 1.8096 + ( ( 17.2694 T ) / ( 237.3 + T ) )]
where
Td = Dew Point Temperature (°C)
Dew-point temperature td is the temperature of moist air saturated at pressure p, with the same humidity ratio W as that of the given sample of moist air. It is defined as the solution td ( p, W) of the following equation:
Td =(237.3 * B) / (1 - B)
where
B = intermediate value (no units)
- Absolute Humidity, Relative Humidity, Specific Humidity
- HVAC ASHRAE Psychometric Chart
- Wet Bulb Temperature Equation
- Humidity Ratio of Air
- Water Vapor Permeability
- Water Vapor Released by Humans
- Boiling Point of Water at Various Pressures
- Water Vapor Density
- Water - Density Viscosity Specific Weight
Source
References: Abbott, P.F., and Tabony, R.C. 1985. The estimation of humidity parameters. Met. Mag., 114, 49-56.
Bureau of Meteorology. 2003. Equipment Specification A2669. 215pp.
