Engineers Edge
This calculator will provide pressure conversions.
Pressure (symbol: P or p) is the ratio of force to the area over which that force is distributed.
Pressure is force per unit area applied in a direction perpendicular to the surface of an object. Gauge pressure (also spelled gage pressure) is the pressure relative to the local atmospheric or ambient pressure. Pressure is measured in any unit of force divided by any unit of area. The SI unit of pressure is the newton per square metre, which is called the pascal (Pa) after the seventeenth-century philosopher and scientist Blaise Pascal. A pressure of 1 Pa is small; it approximately equals the pressure exerted by a dollar bill resting flat on a table. Everyday pressures are often stated in kilopascals (1 kPa = 1000 Pa).
First, type the number you wish converted here:
Then, click radio buttons for desired conversion:
sq cm
kg/
sq cm
lb/
sq in
atmospheres
Hg*
Meters
Hg*
Inches
H2O*
Meters
H20*
Inches
H20*
Feet
To: megadynes/
sq cm
kg/
sq cm
lb/
sq in
atmospheres
Hg*
Meters
Hg*
Inches
H2O*
Meters
H2O*
Inches
H20*
Feet
Standard columns of Mercury at 0o C, g = 980.665 cm/sec/sec
Standard columns of Water at 60o F, g = 32.1756 ft/sec/sec
Conversion Table for units of pressure
Pa
N / m2
bar
mbar
μbar
dyn / cm2
Torr
mm Hg
micron μ
mTorr
atm
at
mm WS
psi
lbf / inch2
psf
lbf / ft2
Pa
1
1 · 10-5
1 · 10-2
10
7.5 · 10-3
7.5
9.87 · 10-6
1.02 · 10-5
0.102
1.45 · 10-4
2.09 · 10-2
bar
1 · 105
1
1 · 103
1 · 106
750
7.5 · 105
0.987
1.02
1.02 · 104
14.5
2.09 · 103
mbar
100
1 · 10-3
1
1,000
0.75
750
9.87 · 10-4
1.02 · 10-3
10.2
1.45 · 10-2
2.09
μbar
0.1
1 ·10-6
1 · 10-3
1
7.5 . 10-4
0.75
9.87 · 10-7
1.02 · 10-6
1.02 · 10-2
1.45 · 10-5
2.09 · 10-3
Torr
1.33 · 102
1.33 · 10-3
1.33
1,330
1
1,000
1.32 · 10-3
1.36 · 10-3
13.6
1.93 · 10-2
2.78
micron
0.133
1.33 · 10-6
1.33 · 10-3
1.33
1 · 10-3
1
1.32 · 10-6
1.36 · 10-6
1.36 · 10-2
1.93 · 10-5
2.78 · 10-3
atm
1.01 · 105
1.013
1,013
1.01 · 106
760
7.6 · 105
1
1.03
1.03 · 104
14.7
2.12 · 103
at
9.81 · 104
0.981
981
9.81 · 105
735.6
7.36 · 105
0.968
1
1 · 10-4
14.2
2.04 · 103
mm WC
9.81
9.81 · 10-5
9.81 · 10-2
98.1
7.36 · 10-2
73.6
9.68 · 10-5
1 . 10-4
1
1.42 · 10-3
0.204
psi
6.89 · 103
6.89 · 10-2
68.9
6.89 · 104
51.71
5.17 · 104
6.8 . 10-2
7.02 · 10-2
702
1
144
psf
47.8
4.78 · 10-4
0.478
478
0.359
359
4.72 · 10-4
4.87 · 10-4
4.87
6.94 · 10-3
1
© Copyright 2000 - 2023, by Engineers Edge, LLC
www.engineersedge.com
Advertising | Contact
Privacy Policy
Applications and Design
Beam Deflections and Stress
Bearing Apps, Specs & Data
Belt Design Data Calcs
Civil Engineering
Design & Manufacturability
Electric Motor Alternators
Flat Plate Stress Calcs
Fluids Flow Engineering
Friction Engineering
Gears Design Engineering
General Design Engineering
Hardware, Imperial, Inch
Hardware, Metric, ISO
Heat Transfer
Hydraulics Pneumatics
HVAC Systems Calcs
Economics Engineering
Electronics Instrumentation
Engineering Mathematics
Engineering Standards
Finishing and Plating
Friction Formulas Apps
Lubrication Data Apps
Machine Design Apps
Manufacturing Processes
Materials and Specifications
Mechanical Tolerances Specs
Plastics Synthetics
Power Transmission Tech.
Pressure Vessel
Pumps Applications
Re-Bar Shapes Apps
Section Properties Apps
Strength of Materials
Spring Design Apps
Structural Shapes
Threads & Torque Calcs
Thermodynamics
Physics
Vibration Engineering
Videos Design Manufacture
Volume of Solids Calculators
Welding Stress Calculations
