Press Fit Bushings into Lug Stresses Calculator and Equations
Stresses Due to Press Fit Bushings into Lug or Ring Calculator and Equations
Preview calculator: Press Fit Bushing Design Calculator
Pressure between a lug and bushing assembly having negative clearance can be determined from consideration of the radial displacements. After assembly, the increase in inner radius of the ring (lug) plus the decrease in outer radius of the bushing equals the difference between the radii of the bushing and ring before assembly.
δ = u r i n g u b u s h i n g
where
δ = difference between outer radius of bushing and inner radius of the ring.
u = radial displacement, positive away from the axis of ring or bushing.
Radial displacement at the inner surface of a ring subjected to internal pressure p is
u = D p E r i n g [ C 2 + D 2 C 2 D 2 + μ r i n g ]
Radial displacement at the outer surface of a bushing subjected to external pressure p is
Eq. 3
u = - B p E b u s h [ B 2 + A 2 B 2 A 2 + μ b u s h ]
where
A = inner radius of bushing
B = outer radius of bushing
C = outer radius of ring (lug)
D = inner radius of ring (lug)
Ering = Modulus of elasticity ring
Ebush = Modulus of elasticity bushing
µring = Poisson's ratio
µbush = Poisson's ratio
Dp = external pressure on outer ring
Bp = internal pressure on inner ring
p = pressure
Bushing Press Fit Annotation
Figure 1, Bushing Press Fit Annotation
Substitution of the previous two equations into the first yields:
Eq. 4
p = δ D R r i n g ( C 2 + D 2 C 2 D 2 + μ r i n g ) + B E b u s h ( B 2 + A 2 B 2 A 2 μ b u s h )
Maximum radial and tangential stresses for a ring (lug) subjected to internal pressure occur at the inner surface of the ring (lug) and are
Eq. 5
f r = p
Eq. 6
f t = p ( C 2 + D 2 C 2 D 2 )
Positive sign indicates tension.
The maximum shear stress at this point is
Eq. 7
f s = f t f r 2
The maximum radial stress for a bushing subjected to external pressure occurs at the outer surface of the bushing is
Eq. 8
f r = p
The maximum tangential stress for a bushing subjected to external pressure occurs at the inner surface of the bushing and is
Eq. 9
f t = 2 p B 2 B 2 A 2
The allowable press fit stress should be based on stress corrosion, static fatigue, fatigue life, and the ultimate strength.
  • Bell Helicopter Structural Design Manual, 1977
