Modified Gruebler's Equation for Kinematics Calculator
Mechanics and Machine Design, Equations and Calculators
For a planar mechanism, the degree of freedom (mobility) is given by Gruebler's Equation:
In kinematics the number of mobile links is:
Gruebler's Equation - degrees of freedom (mobility)
F = 3(n – 1) – 2 f1
Modified Gruebler's Equation - degrees of freedom (mobility)
F = 3(n – 1) – 2 f1 - 1 f2
where
f1 = Total number of pin joints (some joints count as f = ½, 1, 2, or 3)
f2 = number of roll-slide contact joints
n = Total number of links (including a fixed or single ground link)
For example,
Example 1: Slider-crank n = 4, f1 = 4, F = 1
Slider-crank
Figure 1 - 4 links (including ground), 4 joints
Example 2: 4-Bar linkage n = 4, f1 = 4, F = 1
4-Bar linkage
Figure 2 - 4 links, 4 joints
  • Erdman, Arthur G., George N. Sandor, and Sridhar Kota, Mechanism Design, Vol. 1, 4th ed.,
    New York: Prentice Hall, Inc.:
  • MIT, Mechanical Design Contest Presentation
