Missing Segment Rectangular Tube Section Concentrated Intermediate Torsional Loading Applied Roarks Formulas fo
Missing Segment Rectangular Tube Section with Concentrated Intermediate Torsional Loading Applied Deflection and Stress Equations and Calculator #10 of 1a Loading.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2, Row 10.
Section Dimensional Definitions Figure 1
(Note: If t/r is small, α can be larger than π to evaluate constants for the case when the walls overlap)
Loading Configuration (Section Shown May not Match Section given in Figure 1)
Left end free to twist and warp, right end free to warp but not twist.
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam
Figure 2
Loading Declarations Image (Section Shown May not Match Section given in Figure 1)
Concentrated intermediate torque of Channel Beam
Concentrated intermediate torque of Twin Channel With Flanges Inward Beam Orientation Declarations Image
Figure 3
Preview: Missing Segment Rectangular Tube Section Beam Thin Wall Stress and Torsional properties #10 Calculator
Missing Segment Rectangular Tube Section Properties Constants Formulas See: Figure 1
Constant e
Constant K
Constant Cw
Stress throughout the thickness at corners A and B
throughout the thickness at points A and E
Shear stress due to warping rigidity
Shear Stress
throughout the thickness at point C
Shear stress due to torsional rigidity
Torsional Shear Stress
at the surface everywhere
Left end free to twist and warp, right end free to warp but not twist Formulas:
Angle constants theta
Functiona 1,2,3,4
Functions fa1, fa2, Fa2, etc
Sinh functions
Ca1... functions
Area functions
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2);
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x;
A, B, C, D, E, F, e, h, b1= Dimensional data Figure 1 (in, m).
Unit step function defined by use of ⟨ ⟩
⟨ x - θ ⟩0
if x < a, ⟨ x - a ⟩n =0;
if x > a, ( x - a) n ;
The function sinh β⟨ x - a ⟩ is defined as zero if x < a
β = ( KG/CwE)1/2
Supplemental selected special cases and maximum values (not included in calculator).
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Formulas for torsional properties and stresses in thin-walled open cross sections.
