Machining and Material Removal Rate Calculator
Manufacturing Process and Design
This calculator will perform the following calculations, Drilling Material Removal Rate, Slab Milling Material Removal Rate, Feed per tooth f, and Face Milling Material Removal Rate.
MRR = ( π / 4 ) D2 f N
where
D = drill diameter,
f = feed rate,
N = rpm of the drill.
Power = MRR × specific power
Cutting speed is the peripheral speed of the cutter
V = π D N
where:
D = cutter diameter, and
N = cutter rpm.
Feed per tooth f is given by
Eq. 3
f = v/(N n)
where
v = workpiece speed
n = number of teeth on the cutter.
t = (l + lc)/v
where
t = cutting time,
l = length of workpiece, and
lc = additional length of cutter’s travel
= ( D d )0.5
If lc<< l
MRR = lwd/t,
where
d = depth of cut,
w = min (width of the cut, length of cutter)
cutting time = t = l/v.
MRR = width × depth of cut × workpiece speed
Cutting time = ( workpiece length + tool clearance ) / workpiece speed
= (l + 2 lc)/V
feed (per tooth) = = V/(Nn)
lc = tool travel necessary to completely clear the workpiece; usually = tool diameter/2.
Source
Fundamentals of Engineering Supplied Reference Handbook, Fifth Edition
National Council of Examiners for Engineering and Surveying
