Kinetic Theory of Gases Simulator
Kinetic Theory of Gases Simulator Python Script Application
Use this Python code to simulate the kinetic energy of gases in an enclosed volume.
The kinetic theory of gases is a simple classical model of the thermodynamic behavior of gases. It treats a gas as composed of numerous particles, too small to see with a microscope, which are constantly in random motion. Their collisions with each other and with the walls of their container are used to explain physical properties of the gas for example, the relationship between its temperature, pressure, and volume.
NOTE:
Refunds are not awarded after Python files have been downloaded - review your membership agreement for details.
​Units (if utilized) utilized within calculators are either SI or Imperial (some enable both SI and Imperial) and member (you) are responsible for conversions. Ensure that you verify units utilized in excel application meet your requirements before downloading.
Download: Kinetic Theory of Gases Simulator
Output
Editable Data:
  • Second per tick
  • Dimensions
  • Number of balls
  • Average radius
  • Average density
  • Average velocity
  • average speed
Animation of gasses
Data output kinetic gas simulation
Source
No requirements outside the Python Standard Library
Support:
  • Engineers Edge has tested the basic functions and operation of this application using Python 3.11.9 and supporting modules.
  • Supporting Windows application "Visual Studio Code".
  • THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
