Continuous Plate Supported on an Elastic Foundation Stress and Deflection Equation and Calculator
Continuous Plate Supported on an Elastic Foundation of Modulus k (lb/in2/in) Stress and Deflection Equation and Calculator.
Uniform loading over a small circle of radius ro, remote from the edges.
Uniform Loading over a
Small Circle of Radius ro, Remote from Edges ![]() |
Stress Under Load
Max. Foundation Pressure
Deflection:
W = Total load (force) (lbs)
E = Modulus of Elasticity (lb/in2)
Do = Diameter where loading applied (in)
ro = Radius where loading applied (in)
k = Foundation of Modulus (lb/in2/in)
σa = stress, (lbs/in2)
qo = Maximum Foundation Pressure (lbs/in2)
ymax = Deflection (in)
