Conical Helical Compression Spring Design Equations and Calculator
Spring Engineering and Design
Conical Helical Compression Spring Design Equations and Calculator.
This is a helical spring in which the coils progressively change in diameter to give increasing stiffness with increasing load. It has the advantage that the compressed height is small.
Conical Helical Compression Spring Equations and Calculator
Load W
Load C Constant
Stiffness:
Stiffness Equation
Allowable Working Stress (MPa) For Helical Springs (Grade 060A96)
Spring
Wire Diameter (mm)
1 - 3.9
4 - 7.9
8 - 12
Light Duty
590
510
450
Medium Duty
470
410
360
Heavy Duty
400
340
300
Conical helical spring Symbols used:
W = Load (N),
s = Stiffness (N/mm)
G = Shear Modulus (Torsional) of Elasticity (N/m2 or Pa),
τ = Allowable shear stress (Pa),
D1 = smaller diameter (mm),
D2 = larger diameter (mm),
d = wire diameter (mm),
n = number of active coils,
y = Deflection (mm),
C = Coil ratio,
K = Wahl factor,
Mechanical Engineers Databook, Carvil
