Composite Sandwich Stiffness Equation and Calculator
Structural Composite Sandwich Stiffness Equation and Calculator
The analysis procedures described on this webpage apply to composite sandwich structures having isotropic facings and either orthotropic or isotropic cores. The isotropic materials are those having essentially constant properties in all directions. The orthotropic materials are those whose strength properties are not constant in all directions, such as honeycomb cores.
The assumption is made that adhesive failure does not occur, a reasonable assumption if proper care is taken in the selection of the adhesive system. This requires that the adhesive shear and flatwise tensile strength be greater than the respective core strength.
If the sandwich has thin facings on a core of negligible bending stiffness, as is usually the case, and after assuming λ1 = λ2 = λ3, the bending stiffness is given by the formula:
Eq. 1, for unequal facings
Eq. 2, for equal facings
Eq. 3
λ = ( 1 - µ2 )
Where
E' = effective Modulus of elasticity, lbs/in2
t = thickness, in
µ = Poisson's ratio
h = distance between facings centroids, in
D = Bending stiffness, lbs·in2
The notation used
1- subscript denoting facing 1
2 - subscript denoting facing 2
Effective elastic moduli of a heterogeneous body would be the ratios of the average stresses to the average strains that result in the body when it is subject to pure shear or pure compression on its outer boundary.
Figure 1, show the notation used for the analysis of sandwich panels in this webpage.
Source
Bell Helicopter Structural Design Manual, 1977
- Structural Composite Sandwich Design and Analysis in Aerospace Applications
- Advanced Composites Design and Applications
- Short Fiber Plastic Base Composites Engineering Design Handbook
- Fibrous Composites Design and Analysis
- Joints in Polymeric Composites
- Concurrent Engineering For Composites
- Composite Engineering Materials Review
- Joining of Advanced Composites Engineering Design Handbook
- Composites Materials Handbook, Volume 1
- Polymer Matrix Composites Materials Handbook, Volume 2
- Composites Material Usage, Design, and Analysis Handbook, Volume 3
- Metal Matrix Composites Handbook, Volume 4
- Ceramic Matrix Composites Design Handbook, Volume 5
- Design for Machining Fiberglass and Composites
- Honeycomb Beam Spreadsheet Calculator
- Intracell Buckling Honeycomb Sandwich Panels Excel Calculator
