Helical Compression Spring Design Calculator - Engineers Edge
Compression Spring Equations | Engineering Calculators
Compression Spring Calculator
This Helical Compression Spring Design Calculator will calculate any of the values remaining by changing one of the variables then selecting the "calculate: button for the selected variable. Compression spring: is designed to operate with a compression load, so the spring gets shorter as the load is applied to it.
To see the equations dehind this calculator, see -
Helical Compression Spring Design Equations
Compression Spring
 Spring Length (in.) Ddeflected
Spring Constant (lbf/in)  K
Spring Force (lbf)  F
Spring Length (in.) Dstanding
