Column Loading and Elastic Stability Case 1e Formulae and Calculator
Column Loading and Elastic Stability Formulae and Calculator Case 1e
Stepped straight bar under end load P1 and intermediate load P2; both ends fixed
Stepped straight bar under end load P1 and intermediate load P2; upper end pinned, lower end fixed
Preview: Column Loading and Elastic Stability Calculator Case 1e
NOTATION:
P1 = Load (force) (lbs, N);
P2 = Load load (force) (lbs, N);
p' = critical unit load (force per unit length), (lbs, N);
T' = critical torque (force-length A.R.) (in-lbs, N-mm);
M' critical bending moment (force-length);
l = Length of bar (in, mm),
K1 = Derived from ratios as follows (see table):
1.) ( E2 I2 ) / ( E1 I1 )
2.) a / l
3.) P2 / P1
Formulae:
P'1 = ( K1 π2 E1I1 ) / l2
