Column Loading & Elastic Stability Case 3B1 Formulae and Calculator
Column Loading and Elastic Stability Formulae and Calculator Case 3B1.
Uniform straight bar under end load P and a uniformly distributed load p over an upper portion of the length; several end conditions Upper end free, lower end fixed.
Preview: Column Loading and Elastic Stability Calculator Case 3b1
NOTATION:
P = Load (force) (lbs, N);
l = Length of bar (in, mm),
1.) a / l
2.) P / pa
Formulae:
(pa)' = K ( π2 E I ) / l2
