Circular Ring Stress and Deformations Formulae and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator.
Loading W applied at 180° through center of circular section
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9
Circular Ring Loading
Circular Ring Dimensional
Properties
Resultant moment, hoop load, and radial shear
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
LTM = ( - W R z ) / 2
LTN = ( - W z ) / 2
LTv = ( - W u ) / 2
MA = ( W R k2 ) / π
NA = 0
VA = 0
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
W = load (force);
Z = Plastic section modulus
v = Poisson’s ratio;
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
