Circular Ring Analysis No 21 Roarks Formulas for Stress and Strain Equations and Calculator
Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #21.
Per. Roarks Formulas for Stress and Strain Formulas for Circular Rings Section 9, Reference, loading, and load terms #21. Formulas for moments, loads, and deformations and some selected numerical values.
Ring rotating at angular rate ω rad/s about an axis perpendicular to the plane of the ring. Note the requirement of symmetry of the cross section.
![]() δω22πRR0A Circular Ring Loading #21 |
Preview: Circular Ring Moment, Hoop Load, and Radial Shear Calculator #21
θ ≥ π / 2
Moment
Hoop Stress
N = NA u + Va z + LTN
Radial Shear
V = - NA z + VA u + LTv
For 0 < x < 180°
Change Size Horizontally
Change Size Vertically
Change in Pipe Length
Note: The constant KT accounts for the radial distribution of mass in the ring.
KT = 1 + I / ( A R2 )
α = e / R for thick rings
α = I / AR2 for thin rings
A = π [ R2 - Ri2 ]
β = FEI / GAR2 for thin rings
k1 = 1 - α + β
k2 = 1 - α
Plastic section modulus
F = Z / I c
Z = Zx = Zy = 1.33R3
ω = Angular rate of rotation rad/s;
∂ = Mass density of ring material;
Z = Plastic section modulus
v = Poisson’s ratio;
v = unit loads (force per unit of circumferential length) (lbsf/in, N/m);
t = wall thickness
s = sin θ
c = cos θ
z = sin x,
u = cos x
n = sin Φ
m = cos Φ
Roarks Formulas for Stress and Strain, 7th Edition, Table 9.2 Reference No. 21, loading, and load terms.
