Channel Section with Left End Free to Twist Right End Fixed Equations and Calculator
Channel Section with Left end free to twist and warp right end fixed (no twist or warp) Deflection and Stress Equations and Calculator.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2, Loading Configuration 1b.
Channel Section Dimensional Definitions
Figure 1
Loading configuration left end free to twist and warp right end fixed (notwist or warp)
Figure 2
Concentrated intermediate torque of Channel Beam
Concentrated intermediate torque of Channel Beam Orientation Declarations Image
Figure 3
Preview: Channel section thin wall stress and torsional properties #1b calculator
Channel Section Properties Constants Formulas See: Figure 1
Constant e
Constamt K
Constant Cw
throughout the thickness at corners A and D
throughout the thickness at a distance
from corners A and D
Torque 1
Left end free to twist and warp, right end free to warp but not twist Formulas:
Angle constants theta
Functiona 1,2,3,4
Functions fa1, fa2, Fa2, etc
Sinh functions
Ca1... functions
Area functions
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2)
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x.
Unit step function defined by use of ⟨ ⟩
⟨ x - θ ⟩0
if x < a, ⟨ x - a ⟩n =0;
if x > a, ( x - a) n ;
The function sinh β⟨ x - a ⟩ is defined as zero if x < a
β = ( KG/CwE)1/2
Supplemental selected special cases and maximum values (not included in calculator).
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Loading Configuration 1b. Formulas for torsional properties and stresses in thin-walled open cross sections.
