Channel Section Intermediate Torque Applied No1 Roarks Formulas for Stress and Strain Equations and Calculator
Channel Section with Concentrated Intermediate Torque applied Deflection and Stress Equations and Calculator #1a.
Formulas for the elastic deformations of uniform thin-walled open members under torsional loading.
Per. Roarks Formulas for Stress and Strain - Formulas for torsional properties and stresses in thin-walled open cross sections, Table 10.2.
Channel Section Dimensional Definitions
Figure 1
Left end free to twist and warp, right end free to warp but not twist.
Concentrated intermediate torque of Channel Beam
Figure 2
Concentrated intermediate torque of Channel Beam Orientation Declarations Image
Figure 3
Preview: Channel section thin wall stress and torsional properties #1 calculator
Channel Section Properties Constants Formulas See: Figure 1
Constant e
Constamt K
Constant Cw
throughout the thickness at corners A and D
throughout the thickness at a distance
from corners A and D
Torque 1
Left end free to twist and warp, right end free to warp but not twist Formulas:
Angle constants theta
Functiona 1,2,3,4
Functions fa1, fa2, Fa2, etc
Sinh functions
Ca1... functions
Area functions
Point 0 indicates the shear center se "Concentrated intermediate torque of Channel Beam Orientation Declarations image ";
G = modulus of rigidity (shear modulus) of the material (lbs/in2, m2)
θ', θ'', θ''', = are the successive derivatives of y with respect to the distance x.
Unit step function defined by use of ⟨ ⟩
⟨ x - θ ⟩0
if x < a, ⟨ x - a ⟩n =0;
if x > a, ( x - a) n ;
The function sinh β⟨ x - a ⟩ is defined as zero if x < a
β = ( KG/CwE)1/2
Large image click this text
Supplemental selected special cases and maximum values (not included in calculator).
Roarks Formulas for Stress and Strain, 7th Edition, Table 10.2 and 10.3 Formulas for torsional properties and stresses in thin-walled open cross sections.
