Beam on Elastic Foundation Case 1 Calculator and Equations
Beam on Elastic Foundation Calculator and Equations Loading Case 1
Single load at center of Beam
Elastic Beam Loading Single point
Elastic Beam Loading Single Point
When a beam rests on one or more elastic foundations the final beam deflection and internal shears and bending moment depends on the foundation stiffness as well as the beam stiffness. To make the equation convenient the foundation constant β is available from Figure 1 and the damping functions (γ, λ, ψ, η,) are obtained from Figure 2.
Preview: Beam on Elastic Foundation Calculator and Equations Loading Case 1
Foundation Constant B
Figure. 1. Foundation Constant β
Damping Functions
Figure 2 Damping Constants
M = -P ( η ) / ( 4 β )
V = -P ( λ ) / 2
Eq. 3
y = P β ( γ ) / ( 2 K )
Eq. 4
K = p / y
Eq. 5
β = [ K / ( 4 E I ) ] (1/4)
Eq. 6
γ = e-βx ( cos βx + sin βx )
Eq. 7
ψ = e-βx sin βx
Eq. 8
η = e-βx ( sinβx - cosβx )
Eq. 9
λ = e-βx cos βx
Declarations
P = Applied Load (lbs)
p = Load per unit length (lbs / in)
M = Moment (in-lbs)
V = Shear (lbs)
E = Modulus of Elasticity (psi)
I = Area moment of inertia (in4)
K = p / y = spring constant of the foundation
p = load per unit length lbs/in
y = deflection (in)
x = distance from applied force (in)
Note: The beam must extend a minimum distance x = 5 / β beyond the applied loads of moments
β = Foundation constant
ψ = damping constant (Figure 2)
η = damping constant (Figure 2)
γ = damping constant (Figure 2)
λ = damping constant (Figure 2)
Credits:
M. Hete’nyi, “Beams on Elastic Foundation”
