Bazin Formula for Weirs Formulae and Calculator
Bazin Formula for Weirs Formula and Calculator
The Bazin formula (lengths from 1.64 ft to 6.56 ft under heads from 0.164 ft to 1.969 ft) is
The bracketed term becomes negligible for low velocities of approach.
where
H = head on weir in feet (or meters) (height of level liquid surface above crest)
b = length of weir crest in feet
Q = flow in cfs
Z = height of the weir crest above the channel bottom feet
Schaum's Outline of Fluid Mechanics and Hydraulics
- Proportional Weirs Equations and Calculator
- Trapezoidal Weirs Flow Formula and Calculator
- Water Flow Over Rectangular Weir Formula and Calculator
- Triangular Weirs Flow Formula and Calculator
- Dams Spillway Flow Calculator
- Fteley and Streans Formula and Calculator
- Parshall Flume Flow Measurement Equations and Calculator
- Hydraulic Jump Equations and Calculator
- Orifice Submerged in Liquid Discharge Rate Calculator and Equation
- Partially Full Pipe Flow Calculator and Equations
- Weymouth Pressure and Flow Formula and Calculator
- Sluice Gate Flow Formula and Calculator
- Flow over Channel Rise Hump Formula
