2nd Equation of Motion Final Position Calculator
Engineering Physics
In mathematical physics, equations of motion are equations that describe the behaviour of a physical system in terms of its motion as a function of time.This equation applies to a particle moving linearly, in three dimensions in a straight line, with constant acceleration. Since the vectors are collinear (parallel, and lie on the same line) – only the magnitudes of the vectors are necessary and because the motion is along a straight line, the problem effectively reduces from three dimensions to one.
The bending stress for Arc Beam Spring can be determined as follows:
x = ( a · t2 ) / 2 + vo · t + xo
x = Final position (m)
a =Acceleration (m/s2 )
t = time (s)
vo = Initial linear velocity (m/s)
xo = Initial position (m)
