Related Resources: belt design
Synchronous Timing Belt Lengths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804
Synchronous Timing Belt Standard Pitch Lengths and Tolerances per. ANSI RMA IP-24, ISO 5299 and IS 9804.
The pitch length of a synchronous belt is determined by placing the belt on a measuring fixture having two pulleys of equal diameter, a method of applying force, and a means of measuring the center distance between the two pulleys. The position of one of the two pulleys is fixed and the other is movable along a graduated scale.
All dimensions are given in inch units
Synchronous Belt Standard Pitch Lengths and Tolerances ANSI/RMA IP-24
Belt Length
Designation
Pitch
Length
Permissible Deviation
From
Standard Length
Number of Teeth for
Standard Lengths
MXL
(0.080)
XL
(0.200)
L
(0.375)
H
(0.500)
XH
(0.875)
XXH
(1.250)
36
40
44
48
56
3.600
4.000
4.400
4.800
5.600
±0.016
±0.016
±0.016
±0.016
±0.016
45
50
55
60
70
60
64
70
72
80
6.000
6.400
7.000
7.200
8.000
±0.016
±0.016
±0.016
±0.016
±0.016
75
80
90
100
30
35
40
88
90
100
110
112
8.800
9.000
10.000
11.000
11.200
±0.016
±0.016
±0.016
±0.018
±0.018
110
125
140
45
50
55
120
124
124
130
140
12.000
12.375
12.400
13.000
14.000
±0.018
±0.018
±0.018
±0.018
±0.018
155
175
60
65
70
33
150
160
170
180
187
15.000
16.000
17.000
18.000
18.750
±0.018
±0.020
±0.020
±0.020
±0.020
200
225
75
80
85
90
40
50
190
200
210
220
225
19.000
20.000
21.000
22.000
22.500
±0.020
±0.020
±0.024
±0.024
±0.024
250
95
100
105
110
56
60
Belt Length
Designation
Pitch
Length
From
Standard Length
Number of Teeth for
Standard Lengths
MXL
(0.080)
XL
(0.200)
L
(0.375)
H
(0.500)
XH
(0.875)
XXH
(1.250)
230
240
250
255
260
23.000
24.000
25.000
25.500
26.000
±0.024
±0.024
±0.024
±0.024
±0.024
112
120
125
130
64
68
48
270
285
300
322
330
27.000
28.500
30.000
32.250
33.000
±0.024
±0.024
±0.024
±0.026
±0.026
72
76
80
86
54
60
66
345
360
367
390
420
34.500
36.000
36.750
39.000
42.000
±0.026
±0.026
±0.026
±0.026
±0.030
92
98
104
112
72
78
84
450
480
507
510
540
45.000
48.000
50.750
51.000
54.000
±0.030
±0.030
±0.032
±0.032
±0.032
120
128
136
144
90
96
102
108
560
570
600
630
660
56.000
57.000
60.000
63.000
66.000
±0.032
±0.032
±0.032
±0.034
±0.034
160
114
120
126
132
700
750
770
800
840
70.000
75.000
77.000
80.000
84.000
±0.034
±0.036
±0.036
±0.036
±0.038
140
150
160
ANSI / RMA IP-24
ISO 5299
IS 9804
